Updating viewports
Changes that affect the appearance of a viewport are automatically updated for a wireframe viewport. However, if changes require the viewport to be rendered again, the viewport will be displayed as an out-of-date viewport.
If a layer with an out-of-date viewport is printed, a message prompts you either to print the viewport as an out-of-date viewport or to update the viewport before printing.
Rendered viewport updates occur in the background for Renderworks render modes, and rendered non-section viewport updates occur in the background for Hidden Line and Dashed Hidden Line render modes. You can continue working in the file while the viewports or non-section viewports, respectively, are updating. See Inicio del renderizado de encuadres en segundo plano.
Updating selected viewports
| Command | Path |
| Update Selected Viewports | View Context menu |
To update selected viewports:
Select the viewports.
From the Object Info palette, click Update. Alternatively, select the command, or right-click on the viewport and select Update from the context menu.
Updating all viewports
| Command | Path |
| Update All Viewports | View |
To update all the viewports in the file:
Select the command.
All viewports on all sheet layers are updated.
Canceling viewport updates
| Command | Path |
| Cancel All Viewport Updates | View |
To cancel the updates of all viewports, including those queued to update for background rendering:
Select the command.
The updates are canceled.
To cancel the updates of selected viewports:
From the Object Info palette, click Cancel Update.
